pinion bearing?
Old 02-13-2004, 06:01 PM
BLULS1Z28's Avatar
Default pinion seal
what would make these go bad? i have changed 2 in the last year.
Old 02-13-2004, 11:34 PM
2xLS1's Avatar
Incorrect preload when tightening the pinion nut is one possibility. How are you setting the preload. Also, are you changing the races when you change the bearings?
Old 02-14-2004, 01:04 PM
ta12sec's Avatar
Are you replacing the crush sleeve.
Old 02-14-2004, 01:25 PM
BLULS1Z28's Avatar
Default pinion seal
the shop said its the seal not the bearing. istopped and checked things out today
Old 02-14-2004, 03:00 PM
2xLS1's Avatar
https://ls1tech.com/forums/gears-axles/136587-gear-whine.html
