1350/1310 u joint conversion
Old 04-19-2011, 10:22 AM
FasTimeSS's Avatar
Default 1350/1310 u joint conversion
Where the drive shaft meets the rear end pinon. On the Drive shaft side i have a 1350 because its a big after market driveshaft. well its bolting up to a factory ten bolt which is either a 1310 or 3r. anyways i searched and came across the nappa part number 420-0447 or napa 447, but people were using this for the opposite setup as me ( 12 bolt pinon has the 1350, and they were using the stock Driveshaft with a 1310/3r)
Old 04-19-2011, 10:50 AM
tittan1500's Avatar
it will work, both ways one side is 1310 and the other is 1350
Old 04-19-2011, 11:15 AM
Busy Mopper's Avatar
do u have the exact pn?
Old 04-19-2011, 12:31 PM
i think the napa 447 is a 1350 to a 3r conversion u joint. someone correct me if im wrong
Old 04-19-2011, 01:56 PM
sportfan's Avatar
Spicer #5-447X (1350 to 1350)
Spicer #5-460X (1310 to 1350)
Neapco #2-1153 (3R to 1350)
Old 04-19-2011, 04:49 PM
FasTimeSS's Avatar
exactly.... Neapco #2-1153 (3R to 1350)
napa part number for that matches to the 447
Old 04-21-2011, 07:13 AM
Restricted User
Supers's Avatar
You need the Neapco 2-1153, which is 3r x 1350
Old 04-22-2011, 01:25 AM
ahhwataday's Avatar
O HELL YEA, I need that. Thanks for the reminder
Old 04-26-2011, 02:24 PM
FasTimeSS's Avatar
for any body wondering the GM setup for our cars is a 3r NOT A 1310
Old 04-27-2011, 07:02 AM
Restricted User
Supers's Avatar
I thought you seen the post i stuck in here
Old 08-26-2011, 01:38 AM
Black 99 Bird's Avatar
Size wise, what is the difference between a 3r and 1310?
Old 01-06-2016, 11:34 AM
Senator's Avatar
For clarification - for a stock driveshaft with the Moser 12 bolt 1350 yoke:
This is a 3R or 1344 to 1350 conversion.
Moser offers the Neapco 2-1153 U-Joint
The following parts will also fit, (and likely others)
NAPA 447
Moog 447
Precision 447
Hope this helps the folks out there with the stock d/s and 1350 yoke.
Regards,
Darden
PS I found the Moog 447 at Advance Auto for 29.00 or so. About the best price I have found.
Old 01-06-2016, 04:57 PM
dailydriver's Avatar
I know this is an ANCIENT thread, but i found this out the hard way when I tried to install one of the Summit alloy drive shafts with a stock 10 bolt pinion yoke.
Summit, and I believe Inland Empire ship ALL of their 3rd/4th gen f body drive shafts with a straight 1310 u-joint (BOTH sides).
This WILL NOT work, as you need a 3R to 1310 conversion joint to make it work.
Quick Reply: 1350/1310 u joint conversion
