Aftermarket Aluminum vs. chromoly driveshaft?
Old 05-30-2011, 09:02 PM
raymond mckinney's Avatar
Default Aftermarket Aluminum vs. chromoly driveshaft?
I'm curious on the real weight difference between the two and who has had good and bad luck with either. Also which is smoother? I have a 9 inch going in and im going to change to one or the other.
Old 05-31-2011, 08:00 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
The aluminum shafts are known to be smoother. The point of resonance is higher and usually not in the cruise rpm range. Every car is a bit different in this matter, but there's a reason the factory used aluminum in the 98-02 cars...
Old 05-31-2011, 09:14 AM
So is the weight difference and smoothness worth the extra money for the aluminum shaft?
Old 05-31-2011, 09:52 AM
ssvert99's Avatar
We sell about 4 to 1 aluminum vs steel/chromemoly, and we sell a whole lot of driveshafts... the numbers tell the truth. Quite a bit of difference in weight as well. Less rotating weight=free horsepower
Old 05-31-2011, 10:59 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
http://shop.brutespeed.com/PST-3-1-2...Driveshaft.htm
Here is the alum driveshaft that I sell, that includes the upgraded forged yoke. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 05-31-2011, 01:22 PM
MidwestChassis's Avatar
I walked out in the shop and weighed the PST drive shafts.
13 aluminum
20 Steel
There are many choices of yokes to choose from, knowing the proper one for your application is key. There is always the option for a chrome-moly yoke for the higher hp vehicles.
Old 05-31-2011, 05:39 PM
Thanks guys this was exactly what i was looking to get info on!
Old 05-31-2011, 10:34 PM
Restricted User
Supers's Avatar
Performance, Aluminum has the advantage, better rate of twist before failure, lighter weight, doesn't transmit harmonics as easily as stl.
Old 06-01-2011, 03:20 PM
djfury05's Avatar
isn't it nice when you get the information you are seeking instead of just a link to what you sell
MWC FTW
Old 06-01-2011, 04:21 PM
TransWS6Am's Avatar
MWC FTW
It's really quite annoying.
Old 06-01-2011, 06:41 PM
Ya now i got to spend the extra on a aluminum shaft!
Old 06-01-2011, 06:57 PM
studderin's Avatar
do alum shaft cause anymore driveline stress form being more ridged. What about tire and clutch slip?
For a m6 car on slicks, whats the diffrence in the launch was a alum, and a steel shaft?
Old 06-02-2011, 07:20 PM
Restricted User
Supers's Avatar
Actually they give a little more than stl shafts, AL has a better rate of twist than stl and it doesn't stay stuck there as it will come back.
AL shafts won't absorb as much power as does stl, so when getting to speed i have had nothing but positive with lighter weight AL shafts over stl.
Now remember there is no real this shaft does 1200hp. . .
EVERYTHING changes, what will handle 1200hp in one car at 3" diameter may need 4" diameter in another.
The girl in texas last year almost died from a improperly specd shaft, when it broke at 170 mph and cut thru the car and her helmet, shoulder, ribs, legs arm. . . .
Quick Reply: Aftermarket Aluminum vs. chromoly driveshaft?
