No P-brake, if you narow your rear 3"
I took 3" off each side of the housing. I thought I was going to be able to use the P-brake. After messing with putting it together, I discovered that the bracket that holds the P-brake cable & the regular brake line, is too long outwards. It was into the shield, & the front looked like the cable would have gotten hung up. So out with the cutter & cut that end off the bracket, So I was still able to retain & bolt that bracket up to the LCA, for the use of regular brakes. Probably would have been find iff I would have taken 2.5" off.
Car is an auto, so not a huge deal. I should drop a few lbs by eliminating that. Just a heads up for anyone thinking about narowing the rear.
Thanks for the info!
What size tires areyou runningto need it narrowed three inches?
later,
Bart
later,
Bart
Last edited by Speedfreaks101; 02-29-2004 at 03:16 PM. Reason: To correct my hick grammer
http://community.webshots.com/user/hotrodharry03
Some pics are available in there. I'll have to get a close up of the bracket that I cut off, the ones in there dont show that specifically.
I'll eventually go with a 4" BS rim, and fit the biggest tire (widest) on there I can. The reason for going with 3" is because that was the max that I could take off and still retain stock mounting points. I lost alot of weight by taking off 3". Rotating mass on top of it. I was going for that along with the look of a 5" or 4" BS rim.
