Whats my gear ratio?
Old 08-21-2011, 10:55 PM
98ws6firebird's Avatar
Default Whats my gear ratio?
I have 4:10 gears but changed my tire size from a stock 26'' to a 28'' tall. I know I changed my effective gear ratio but to about what 3.75 or closer to 3.90.
Old 08-21-2011, 11:20 PM
pancho toco loco's Avatar
http://www.f-body.org/gears/ That should help you. More like 3.80's
Old 08-22-2011, 12:18 AM
Thanks...that gives me my mph at a given rpm but how can you calculate et's based on gear ratios. Which gear ratio gives you the fastest et?
Old 08-23-2011, 11:25 PM
Well from what I have been told for all out drag times you want to cross the line right about where you car peaks on the HP curve. On my auto car w/ 26in tire and 4.10's out back i cross the line at around 5800. I've never dyno'd my car to know but being a stock long block it pulls to about 6k, Shifts are set at 5950 1-2 and 5850 2-3. Dont know if the helps but should give you and idea.
