What is all needed for a moser m9 converison into a 01 fbody..
Old 09-13-2011, 11:40 AM
ccrook19's Avatar
Default What is all needed for a moser m9 converison into a 01 fbody..
I'm just wondering what is all needed when your switching over from a 10 bolt to the 9" rear end.. will i need different drive shafts, and yoke? i know about the abs stuff and the torque arm.. and the sway bar bracket.. just wondering if theirs anything else needed for this conversion..
Old 09-13-2011, 12:08 PM
ccrook19's Avatar
also will my magnaflow cat back exhaust fit with the moser m9 set up..
Old 09-13-2011, 05:04 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
You'll either have to get a conversion u joint, Napa 447 is the one most people use, or get a new driveshaft. I do recommend getting a stronger driveshaft, as the stock driveshaft is a weak link. The PST 3.5" aluminum with the forged yoke is what I recommend, here is a link to it. http://shop.brutespeed.com/PST-3-1-2...Driveshaft.htm
Yes, your Magnaflow exhaust system will bolt right up. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 09-13-2011, 06:22 PM
ccrook19's Avatar
Also if i get the back brace on the M9 will that interfere with ever removing the gas tank?, i got a hair over stock setup, so i think i will be good on the drive shaft for now.. I may be looking to get a M9 setup in 2-3 months for a winter build..
Old 09-13-2011, 06:23 PM
ccrook19's Avatar
^last question^ haha Thanks Bob
Old 09-13-2011, 06:46 PM
LS1Tech Sponsor
No the backbrace won't interfere with the gas tank, it doesn't stick out that far. If you have anymore questions, don't be afraid to ask. Thanks. Bob
__________________
Old 09-14-2011, 11:14 AM
ccrook19's Avatar
Thanks alot Bob. Im going to be taking another look at my 10 bolt this weekend to see how bad it is.. if its as bad as i think it is then you may be hearing from me in 2-3 months with a order on a Moser M9 package...
Old 09-14-2011, 02:36 PM
LS1Tech Sponsor
Sounds good, thanks. Bob
__________________
Old 09-14-2011, 03:35 PM
djfury05's Avatar
all that is needed is a MWC fab 9" .. M9's are built quicker though
Old 09-14-2011, 09:10 PM
LS1Tech Sponsor
Yeah, the M9's go out the door in just two days after the order is placed. My Camaro was cutting 1.29 60 ft times with my M9 on dot drag radials. Bob
__________________
Old 09-21-2011, 09:39 PM
bmcfadin85's Avatar
I went for the M9/torque arm package.
Attached Thumbnails What is all needed for a moser m9 converison into a 01 fbody..-img-20110630-00154.jpg   What is all needed for a moser m9 converison into a 01 fbody..-img-20110630-00155.jpg
Quick Reply: What is all needed for a moser m9 converison into a 01 fbody..
