MWC delivers again
MWC delivers again
I would like to thank the entire Midwest Chassis crew for the amazing job they did on my fab 9 and install. First things first, Rome wasnt built in a day, neither are their rear ends; but there is no rushing perfection. From an appearance standpoint the assembly looks like is was assembled by machines, no flaws po r inperfections whatsoever. Their customer service is second to none and knew the answer to every question I had.
I brought my car there this morning and as I type im on my way home already, they pretty just breezed through the install, which is impressive due to the fact that I had a driveshaft failure that fucked up alot of things underneath the car.
Again, thanks for an excellent and professional transaction.
Now on to the specs and pics.....
35 spline axels
Strange S-trac
Aluminum thru-bolt center
4.11 gears
Abs
Watts Link
LCA's
transverse shock mounts
35 spline axels
Strange S-trac
4.11 gears
Abs
Watts Link
LCA's
