do i need to shorten my rear for 305s or 315s?
im goona be ordering an s60 shortly,and i know that in the future i will be going with 305s or 315s..........if using oem z06 wheels orany knockoff replicas, do i need to consider getting a couple inches knocked off of my new rear? thanks
Kleeborp the Moderator™
I have a better idea...run wheels with the proper offset. If you alter the length of the axles and housing, you are going to be stuck running whatever wheels will fit that offset.
The rear housing width has nothing to do with being able to run 315s...the size and shape of the fenders do.
A word of advice from experience .... if you are planning a UMI, BMR or Spohn drag sway bar, be sure to order your rear without the "stock" sway bar brackets. Also to be sure look at your axle stud options .... 12x1.5, 1/2x20 or 5/8 and 1.5"-3" long.
I presume you have decided on your carrier and gear ratio.
