Rear End Leak, Please Help
Old 09-26-2011, 09:53 PM
z-maro's Avatar
Default Rear End Leak, Please Help
I have a leak in my rear end that needs to be fixed. I was wondering if anyone could tell me what seal needs to be replaced, and how big of a job it is. Thanks for the help!
Old 09-26-2011, 11:13 PM
Duffster's Avatar
you're not showing the pinion seal... (from passenger side) but that looks to be the culprit...
Little bit of work for you there. Involves full disassembly of rear end...
Old 09-26-2011, 11:20 PM
01ssreda4's Avatar
Pinion seal. I personally would take it to a rear end shop. It would be a good time to install a set of gears, freshen all the bearings (which helps 10 bolts live longer IMO), and possibly do a solid pinion spacer for strength.
Old 09-26-2011, 11:39 PM
Anthony Williams's Avatar
Yep, about $600.00
Old 09-26-2011, 11:45 PM
01ssreda4's Avatar
It should live forever behind an auto
Old 09-27-2011, 08:20 AM
z-maro's Avatar
Dang, thats more than I thought it would be. I have a friend that works on cars and has a Firehawk as well, that I will see if he can do it. How much would it be for all the parts you recommend, and what all do you recommend doing?
- seals
- bearings
- solid pinion spacer, what does this do?
- gears, for added strength or for better acceleration? I have 3.42's now but could go to 3.73's, 4.10's, 4.30's, or 4.5x's?
Any other recommendations, the car is completely stock and has 62k miles?
Thats great, but what about behind a 6-speed?
Old 09-27-2011, 10:38 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
6 speed, I wouldn't waste your money on the 10 bolt. I'd go with a nine inch rear. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
