How far does the slip yoke need to go in the trans?
Old 10-06-2011, 01:09 PM
AChotrod's Avatar
Default How far does the slip yoke need to go in the trans?
Just put a th350 in my car and it seems the DS fits but does not slide into the trans as far as it used to once you tighten the rear u-bolts. The old yoke seal on the T56 did stick out farther so im sure the visual is a bit off.
Anyways how far does it need to slide into the trans to be safe?
Thanks
Mike
Old 10-06-2011, 04:46 PM
JeffT's Avatar
Bottom the slip yoke out in the transmission and then pull it back 3/4" to 1". If you have to pull it back any more than that to bolt to the pinion yoke you probably need to get the driveshaft lengthened.
Old 10-06-2011, 05:09 PM
AChotrod's Avatar
Ill measure tonight but looks about that. Just strange looking without the factory seal that came out of the T56.
Quick Reply: How far does the slip yoke need to go in the trans?
