Pinion Yoke sleeve removal
Have any of you tried removing the sleeve on the pinion yoke? My 02 firebird pinion seal is leaking and the yoke is grooved from the seal. I want to remove the sleeve on the yoke and use the older style seal. I'm thinking if I heat the sleeve with a propane torch maybe it will slide off easily?
