Does anyone's 10-bolt pinion seal NOT leak?
What type of pinion seal is best for the GM 10-bolt? I have a 2002 Z28 whose pinion seal leaked from day one. I have my rearend apart now to install 3.73s and I want also to eliminate the leak. Part of my problem is that I can’t see why the original seal leaked – it appears to be undamaged. The replacement seal I purchased (Federal Mogul) is a different design than the original seal. Is some particular type or brand known to be best?
TIA, Gary
TIA, Gary
Mine leaked when i got my car also. I thought it was because it gets parked 5 months outa the year. replaced it with a seal i picked up from Napa (dunno the brand or material) and it hasnt leaked in a year.
The pinion seal on the Z28 leaks. My old car was a 2000 T/A, and the stock seal leaked on that also. I installed 4.10 gears in that car and replaced the pinion seal while I was at it and still leaked. I took it apart again and packed some real thick grease in and around the seal and it made it stop leaking.
You can add my car to the leaky pinion seal group Mine has been leaking for a while, though I had no problems with it for over four years before it started to leak. I plan on getting it fixed this week though - hopefully it wil stay fixed :crossedfingers:
The dealership I brought my car to said it was common and it was called, "sweating." He said it wasn't actually leaking, just sweating. After I thought about it, I've never had a drop of rear end fluid hit the pavement where my car has sat. It just seems to, sweat, I guess.
most leaks are caused by ---1 not lubing seal during install and----- 2 clogged vent in the rear to allow fuid to expand and air to vent when heated... hope this helps
I had a 2000 Z28 w/M6. Mine leaked from day one. When I got my 3.73's put in the installer (Pyle Brothers) recommeded installing a yoke kit also(has a outer seal on it), besides the new pinion seal. Never leaked afterwards.
The Firehawk was leaking when we bought it with 700 miles on it....oh well..already blew that rear...have another 10-bolt in there and are just waiting until we can order a 12 bolt.
The WS6 has never leaked...43,xxx miles now...oh well if it ever does cause it's eventually going to have a 12 bolt too...
Originally Posted by Assassin
mine leaked since day 1, replaced and leaked after that too, I even thought about cleaning the spary of oil off from underneath the car but I notice its working as a pretty good rust inhibitor so I'll let it be for now, lol
Im on my 4th seal now I think im just gonna give up on the whole thing kinda like my timing cover....the cars dont run right unles they leak something
