Replacing rear studs question
ok...
I have a 12 bolt differential and want to run longer studs
#1 did my 12 bolt come w/longer wheel studs? The ones i'm going to go up to are 12mmx1.5 2.5" long (ARP )
#2. do I definetly need to pop the diff cover to remove the axles in order to change the studs? Why is this? Why won't they pop back in w/the axle still in?
Thanks!
Thanks!
sweet! I do ! I have the ABS and TCS option so that's 4 channel i believe
Will this work on stock cars too? cause this weekend I'm doing mine and timmah is driving up and we're going to do his on his stock 10 bolt
It should, the hole should be the same size. On mine, it was a PITA getting them by the ABS reluctor "gear" out on the end of the axle, but I did it. Just an FYI, its not as simple as I made it sound. I ended up taking mine out anyways, but the backing plate and "reluctor gear" stayed on.
What else ya gonna do, just your calipers?
Shawn
Shawn
