Trying to identify rear end
Old 11-08-2011, 04:52 PM
Rubedizzle's Avatar
Cool Trying to identify rear end
Got a rear end from an unknown year trans am, I know it had TCS. I am using it for my firebird's drum to disc brake swap.
In any event, was wondering if somebody could confirm what type of differential this is, as I am looking to sell it and don't know a darn thing about it.
Picture is below, I believe it is a Posi-Rear, it was from an automatic car, so I believe it should be 2.73 gears. Can anybody give me any more information about it, that might help?
Thanks!
Old 11-08-2011, 06:46 PM
Duffster's Avatar
I'm guessing the ring gear is around 48 teeth and the pinion is around 14....which is 3.42...
but thats just a guess... you can count for sure...
Old 11-08-2011, 08:23 PM
FirstYrLS1Z's Avatar
differential looks Auburn putting it from a 98 or earlier T/A.From the position of the ring gear in relation to the carrier,it looks to be a 2 series,making it a 2.73:1.
Since it had TCS,95 and later.
from a 95-98.
Old 11-08-2011, 11:27 PM
01ssreda4's Avatar
Looks like an Auburn with a 3.23 to me. There should be identifying numbers around the edge of the ring gear or count the teeth.
Old 11-08-2011, 11:32 PM
southpaw0314's Avatar
my guess would be 3.23 if it was from an auto.
Old 11-09-2011, 07:33 PM
Rubedizzle's Avatar
Thanks for the help folks! Found the numbers on the edge of the ring gear - 41:15, making it a Auburn with 2.73 Gears from a 97 Trans Am.
Thanks a ton, really appreciate everybodies help.
Last question - are these worth much? Found out car it came from had only 70,000kms.
