Stock 10 bolt help
Old 11-11-2011, 06:18 PM
19kiloz28's Avatar
Default Stock 10 bolt help
It's leaking I feel its just a matter of time before it blows up how is this to fix it?
http://www.hawksthirdgenparts.com/ca...entgasket.aspx
Old 11-11-2011, 08:07 PM
camaroz28lt1at's Avatar
Im not really sure what your asking. That wont "fix" anything, the girdle just adds a bit more strength to the already weak 10 bolt.
Old 11-11-2011, 09:02 PM
VandykeT/A's Avatar
If its leaking around the pan just take it off and replace the gasket. I wouldn't waste money trying to beef up a 10 bolt.
Old 11-12-2011, 06:22 AM
FirstYrLS1Z's Avatar
^^^ agree,just get a cover gasket and gear lube and be done with it.
Old 11-12-2011, 08:24 AM
01ssreda4's Avatar
Don't buy from Hawks Third Gen. Bunch of rip off artists. Just fix your leak.
Old 11-21-2011, 02:26 PM
Jazz-LT1's Avatar
Actually if you want to make a little improvement to the 10 bolt I think the girdle is a good cheap improvement. No, it won't make the 10 bolt into a 12 bolt but I really do think there is some advantage in strengthening the case. There are a few 10 bolts around with girdles that have lived pretty good lives. Again, its a minor improvement, but every bit helps.
Old 11-21-2011, 06:58 PM
lazerlemonta's Avatar
I had a stock 10 bolt no girdle live with 4.56s with mid 1.7 and 1.8 60s with around 300 total passes. Still in the car with its new owner.
Old 11-21-2011, 07:34 PM
Capricio's Avatar
I got a Proform "Perfect Launch" 66667, pretty much an identical girdle for less money and better looks, IMHO.
http://www.proformparts.com/product-...ategory_id/298
Also get a tube of Permatex 81182 Permatex® Gear Oil RTV Sealant. A paper gasket will start weeping out the bottom eventually.
http://www.permatex.com/products/Aut...tv_sealant.htm
A couple quarts of gear oil and 3oz of limited slip additive, call it good.
Old 11-22-2011, 09:25 AM
NVR_SPDS's Avatar
I have the summit girdle on mine, and it seems to work just fine.. I dont expect the 10 bolt to last forever though, even behind my auto.
I wouldnt waste the time on a gasket. Just pop the cover, and clean the surfaces REALLY well, and use some good RTV.
Probably wouldnt be a bad idea to clean out the housing, and take a look at the parts to make sure everything looks ok.
Old 11-22-2011, 11:52 AM
96lt1m6's Avatar
Time bomb especially if you have an m6
Quick Reply: Stock 10 bolt help
