10 bolt Posi Failing?
What are the symptoms of a failing posi in a 10 bolt? I tried to do a doughnut and the car just did a wide circle. My brother got out, and said that only one wheel was spinning. WTF?
Can I just replace the posi? I don't have the cash for a 9", so I'll either fix this 10 bolt of pick up a junkyard rear.
What year f-body's have interchangeable rear ends?
95 lt1 Camaro, stock 10 bolt with 4.10 gears.
That would be a toast posi, mine did the same this fall. Next up is a MWC fab 9" because I refuse to put any money towards a/the 10 bolt. I don't know if the LT1 rears are any different than the LS1 rears. Just have to make sure you get the right one, 3 channel or 4. Unless you don't care about losing ABS/TCS if you have it.
And yes, you can just replace the posi.
Where can I get a replacement posi?
3 or 4 channel refers to whether you have traction control or not. t/c= 4 channel.
no t/c = 3 channel. most of the vendors on here sell replacement differentials. i have used
eatons pretty regularly. you will need the differential and bearings.
Would it be a good idea to get a new set of gears as well? I didn't realize these replacement diff's were so expensive. I might just have to deal with it until the 9" funds come in.
Troy5061, Do you have any issues getting your car inspected in Maine with the ORY on it. I am originally from eastern Maine but stationed in Virginia for years now in the military. I was thinking about switching my registrations back over to Maine because Virginia is kind of strict with inspections. I have to pay someone under the table to inspect mine.
