little help with tire size please????
f-body all bolt on car cam only , heads later. a4 car with 3200 stall and 410 gears.what is the tire to get me to the end of the strip 3rd gear max rpm???will a 26*10.5*16 et street work????
stock bottom end so should keep limiter setting factory???? do not want to hammer wheel welds for 28",got 16" rims so no 27" slicks????? the 26" et's i have are not used and if they will not work someone please steer me in the right direction please and thks. should have done more research on tire-rim for 410's,****!!!! any help thks.
LS1Tech Co-Founder
I don't know that cam, so I'll assume you will be spinning your motor to 6400-6500. You should be fine with 26x10.5x16 ET Streets. Worst case you can get 27x10.5x16 ET Streets but I had a light bolton buddy going like 112mph with 4.10's and stock converter, and now he's going 11.3@116mph with drastic weight reduction, 4.10's, and Yank 4400 converter.
thks. psj , do they make 27" et's on a 16" and if they do i am gettin' the impression to go that way,i can exchange the 26" for 27" et's as they are new. thks a bunch!!!!
