Pinion Angle for Moser 9"?
I'm currently running a Moser 9" with my stock torque arm. I have a vibration when I let off of the gas. I had a local shop check everything out. The shop said it was caused by having alot of pinion angle. He said under load everything lines up. Then when I let off the pinion goes down thus cuasing the vibration. He said it looks like the bracket that attaches to the 9" was fabricated for more pinion angle inorder to get it to bit better. Is there any way of adjusting the angle with out having to buy an adjustable torque arm? Does moser make different brackets?
Thanks for the help.
