Lengthing a drive shaft
Is this even possible to do while maintaining the structure of the driveshaft.
It seem it need atleast a half a inch or so more in the trans. The front slip yoke wobbles and I know it is not supposed to wobble to this extent, plus the output shaft seal is leaking
Any input on this
Any input on this
Technically you can! Convert to bolt on yoke at the tranny and install a slip yoke in the shaft! I did that one time and you end up with a stronger system overall without having to buy a whole new set-up if your current set-up is within spec. You can also just have them install a whole new tube if your existing yokes/u-joints are in good condition.
Joe
Joe
