Where can I but a plastic yoke? - LS1TECH
Thread Tools Search this Thread
Old 01-29-2012, 05:06 PM   #1
Brian2001SS's Avatar
Default Where can I but a plastic yoke?
Want to pull the driveshaft so I can paint the underside, but need a temp yoke to keep the fluid from coming out of the tranny. Any sponsors sell something like this?
Brian2001SS is offline   Reply With Quote
Old 01-30-2012, 08:02 PM   #2
can't you just lift the rearend slightly higher
so all the fluid is going towards the front instead of it going
out the tail.
69TA is offline   Reply With Quote
Old 01-31-2012, 08:21 PM   #3
Yeah if the car sits level u will lose only minimal fluid.
Oldsmobility85 is offline   Reply With Quote
Old 01-31-2012, 11:16 PM   #4
My haynes manual just says to wrap a plastic bag over the trans housing.
2QuikTA is offline   Reply With Quote
Old 02-01-2012, 05:44 PM   #5
Thanks guys. Car is setting level, so maybe I will try the bag thing. Then again I'm unsure how that will keep the fluid in.
I just thought a plastic yoke was a common thing. Guess not.
Old 02-01-2012, 07:34 PM   #6
jbridwelltransam's Avatar
I just used a yoke that I had laying around.
jbridwelltransam is offline   Reply With Quote
Old 02-01-2012, 07:52 PM   #7
Moderator
jimmyblue's Avatar
Call it an excuse for an early trans fluid & filter change?
I bet any boneyard has a surplus of stock steel driveshafts
that nobody wants, and a bent one would go for roughly
nothing. Little sawzall session and there's your plug.
jimmyblue is offline   Reply With Quote
Old 02-01-2012, 08:13 PM   #8
01BlackCamaroSS's Avatar
Harbor frieght sells a plug for $6 bucks
01BlackCamaroSS is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
