4.10 gear and 28" tall tires..... Will I run out of gear?
I have a 2000 SS A4 with following mods
Lt's
Ported tb
Lid
True duals
Ms3
3600 stall
And spray.
28" tall DR
Currentley the car has stock 3.23 gears.I run a 325/50/15 out back. I was told that due to tire size my 3.23 was really like a 2.98 gear.
My tuner said to get 4.10's which with my tire would be about a 3.65 gear.
My qusetion is what would it put my rpms at when doing 65-70 mph?
Will I run out of gear in the 1/4 mile if I spray?
I do daily drive the car.
Lt's
Ported tb
Lid
True duals
Ms3
3600 stall
And spray.
28" tall DR
So would u suggest a 3.73 gear or a 3.90?(if u can get a 3.90 for a 10 bolt)
Cause I am still on a stock 10 bolt. And that's why I didn't change gears is to keep the bigger pinion gear of my 3.23'
what tranny a 3 speed. and i got a th400 and i just had 4.11 with a 28" slick and it screemed at 65 to 70 and i talked to alot of people on this forum and others forums told me to run a 3.25 so thats what i just put in.
Im with Kidmaro, at 600rwhp on spray with 27" tires, 4:10, and a T56 i was out of gear but also ran 132mph too. If you are planning on running faster than that then move to a rear 3:90 gear, which is better for DD anyways.
Yes you can get a 3:90 in the 7.5 gear set series.
Lt's
Ported tb
Lid
True duals
Ms3
3600 stall
And spray.
28" tall DR
Lt's
Ported tb
Lid
True duals
Ms3
3600 stall
And spray.
28" tall DR
im running 600rwhp as well on a 150 shot. I had a 26" MT on there before and spraying the gears werent long enough for me, so I stepped up to a 28" nitto and its much better.
You news to figure out your converter slip percentage to determine your rpm. That calculator assumes a locked converter. tci.com has some calculators that include converter slip into their calculation. Keep in mind you converter will slip more when sprayed.
