four channel to 3 channel conversion
Old 02-09-2012, 11:48 PM
cfiester's Avatar
Default four channel to 3 channel conversion
I just purchased a used moser 9 3 channel complete housing. I was going to install it in my 98 SS but i picked up a 12 bolt for it. I want to put the 3 channel 9 inch in my 01 firebird. My bird is a four channel. I think i am pretty much screwed cause the 4 channel has the same sized pulse wheel on all four corners. Is it possible to tie the two channels off the rear together and run off the signal signal? Use a resistor to cut the signal to match the front signal? Any input would be apreciated.
