1/4 mile RPM's
Old 02-17-2012, 08:45 AM
njmaster's Avatar
Default 1/4 mile RPM's
I have an A4/LS1 with 4.10's and i will be adding a 3600 stall. I am wondering what kind of rpms i will be turning running the 1/4 mile??
Old 02-17-2012, 09:52 AM
Big Al's Avatar
Depends on a lot of other things like how fast the car runs and how tall the tires are. There are a ton of MPH RPM calculators on the web.
http://www.bgsoflex.com/rpmmph.html
And a hundred more are out there. One thing more you need to know is how much your converter slips. Rule of thumb is around 10%, but they vary.
Al 95 Z28
Old 02-17-2012, 10:01 AM
Old School Heavy
speedtigger's Avatar
Here is a better calculator. Figure in about 7% converter slip for unlocked.
http://www.hotrodpitstop.com/tool.php#7
Old 02-17-2012, 12:05 PM
njmaster's Avatar
appreciate the help fellas.
Old 02-17-2012, 12:11 PM
njmaster's Avatar
Alright so i used the calculators and i had to estimate the mph because i haven't ran the car yet. I estimated around 115 or 120 for mph and with my tire height i'm getting around 6500-6600 rpm. Is that too high for the quarter? should i think about replacing the gear with a 3.73?
Old 02-17-2012, 12:22 PM
Old School Heavy
What RPM do you plan on shifting the car?
Old 02-17-2012, 12:50 PM
njmaster's Avatar
I'm not really sure?? I will be running a 3600 stall with futrals f13 cam? It stops making power around 6800 rpm?
Old 02-17-2012, 01:43 PM
Old School Heavy
Really you could run either gear and not notice much performance difference. Depends on how hard core you are. If you want every last hundredth of quarter mile performance then go 4.10. If you do any amount of highway driving, you might choose the 3.73.
Old 02-17-2012, 02:41 PM
PlowBoy11's Avatar
I have a 98 Pretty stock LS1/A4 with 100 shot, 4:10s and 26 DR Stock stall last year. Car went 12.4 at about 112 would hit 4th gear right at 1/4 mile mark. Car is also a DD car cruises 26ish at 70. Put a 3400 stall in it this winter. Love the 4:10s in mine. 3:73s would not be bad either I bet.
Old 02-17-2012, 03:34 PM
Silver LS1's Avatar
Why not lock the converter up once you pull high gear? Then it will be the same as you are currently running through the traps at.
Quick Reply: 1/4 mile RPM's
