What's inside a stock m6 driveshaft that could come loose?
Old 02-19-2012, 07:41 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Default What's inside a stock m6 driveshaft that could come loose?
So I pulled my driveshaft yesterday as I'm pulling the motor, and as I lower the one end, I hear something move and thud inside the driveshaft. So I pulled the driveshaft and tilt it the other way and sure enough, something is loose inside it that when you tilt it, it slowly moves. From the sound of it, it's cylindrical in nature as it's not 'rolling' but sliding down the length of the driveshaft.
Anyone else experience this?
Old 02-19-2012, 08:45 AM
wrd1972's Avatar
Sometime they put cardboard or some other dampening object in the tube to reduce vibes, again a dampener. Just ignore it.
Old 02-19-2012, 09:47 AM
UNDER PRESSURE MOD
Ok. It does sound like it could be cardboard since it has a quiet, soft type of thump, nothing that would be metallic.
Old 02-19-2012, 09:55 AM
djfury05's Avatar
yep its cardboard
Old 02-20-2012, 07:09 AM
UNDER PRESSURE MOD
Ok, so is it an issue that it's loose? If it's a dampner, then I guess it's fine.
Old 02-20-2012, 03:52 PM
HoLLo's Avatar
Definitely cardboard tube. When mine split apart I found it and had nothing but a WTF look on my face I'm sure.
It's not supposed to be loose, it's supposed to fit tight on the inside of the driveshaft. What is a realistic reason for it? I'm not sure. I don't see it dampening ****. Maybe absorb some SLIGHT vibrations??
Old 02-21-2012, 12:10 AM
shepss217's Avatar
wow, that's the first time i've heard of this....interesting
