Diffs for the Moser 12 bolt: how are they different?
The diff for the 4.11 and higher is different from the lower gear ratio. Its some sort of modified Eaton, but not a true Eaton. Eaton doesn't make one for 33 spline axels, the type available for the 4.11.
So, what's the diff (NPI)?
Steve
Steve
As fars as I know there is only one eaton posi for 12 bolt car axles (well two if you count 3 series and 4 series). Moser modifies (or manufactures) side gears to use 33 spline axles. I see some people referring to a 'HD' eaton but I though they only made one eaton model differential for 12 bolts.. Could be wrong though
