Width, flange to flange?
So in preparation for the day when my second 10 bolt will likely die, I'm measuring the 1st 10 bolt I pulled out of my car.
It's a 4 channel rear and I'm getting 66 inches from axle flange to axle flange, is that right? I'm measuring with two T-squares for drywall since I don't trust a measuring tape.
(You would think the axle housing width and flange to flange width would be a sticky).
I'm going to build a custom rear end but I want to keep my Tomz ZR1s if possible.
so with a 2.75 offset from the flange for the backing plate, it should be about 64 11/16.
That'd be perfect. Hopefully my wheels aren't pulled in an inch since the 17x11s already rub the bumpstops.
