3.90 Gear Set bites the dust
Old 03-25-2012, 05:57 PM
onequickz06's Avatar
Default 3.90 Gear Set bites the dust
Alright rear diff is being sent to DTE for an inspection/rebuild. First look says 3.90 ring and pinion failed.
FYI. 06 Z06 530hp 464lb
What route would you take?
Save for the next rainy day with the vett rebuild with parts that are fine just replace the ring and pinion.
Spend so hopfully wont have issues in the future but s.o.l if somthing breaks for awhile.
Ideas?
