Need info on rearend asap look inside
Old 04-21-2012, 02:20 PM
2000whitevert's Avatar
Default Need info on rearend asap look inside
Tearing my rearend apart today n i cant get the cclip on the passenger side out the car has a torsen posi is there some sort of trick to this???? The driver side pushed in n popped out with no issues passenger side is being rediculous any advice?
Old 04-21-2012, 03:07 PM
sreve's Avatar
Tap on the axle with the BFH?
Old 04-21-2012, 03:47 PM
Idk what to do the cclip is too far down in its groove its moving around and everything just cant get it to fall ive never had this much trouble with this before its ******* stupid any1 that can help it would save me a lot of frustration
Old 04-21-2012, 04:11 PM
fastassls1maro's Avatar
Remove the wheel speed sensor to allow the axle to slide in further.
Old 04-21-2012, 04:40 PM
heymoej's Avatar
^^^^^^^^^^^^^^this.
Old 04-21-2012, 06:00 PM
FirstYrLS1Z's Avatar
3 situations will prevent the axle going in far enough to allow removal of c-clip
-4 channel sensor in backing plate
-axle bearing has been replaced by an 'axle bearing saver' assembly
-twisted splines immediately outside of the carrier splines
