Vibration after rearend install
Old 04-25-2012, 11:10 AM
94dragbird's Avatar
Before install. Yank ss3600, flt lvl7 with billet shafts, speed inc chromoly driveshaft and a pst aluminum shaft, s60 with locker, stock length, umi adj. Tq arm and lower control arms, umi subframe connecters
Old 04-25-2012, 11:26 AM
94dragbird's Avatar
Before. Its been in there since last spring(2011)
Old 04-25-2012, 11:37 AM
Punisher_ws7's Avatar
Is the car lowered?.. ive been chasing this problem for over a year.... biggest parts we have in common is the trans mount and adj umi torque arm.... what angle do u have urs set at and where did u take ur measurements From
Old 04-25-2012, 11:45 AM
94dragbird's Avatar
Not lowered and I haven't measured just eyed
Old 04-25-2012, 01:26 PM
Blu99T/A's Avatar
More than likely your problem.
Old 04-25-2012, 09:16 PM
i would measure the rear end and the drive shaft with a angle finder.... add them together to get -2 degrees
Old 04-26-2012, 08:14 AM
94dragbird's Avatar
Ill try it and see what happens.
Old 05-02-2012, 09:22 AM
any update?.... i know stock ride height is sussposed to be at -2 but dont know where its susposed to be when lowered ... my drive ashaft is 0 and rear end is -3
Old 05-02-2012, 09:42 AM
94dragbird's Avatar
I haven't had much time to mess with it but its narrowed down to the carrier or driveshaft balance/angles
Old 05-02-2012, 06:50 PM
Blwn_by_Twins's Avatar
Chassis mount ta? I'm getting a lot of vibration from my MWC 9" and I think it's b/c of the t/a being mounted to the chassis.
Old 05-02-2012, 07:21 PM
94dragbird's Avatar
Its a full length umi tq arm with a umi relocation kit but it uses a poly mount
Old 05-03-2012, 04:22 PM
  #32
sully91rs's Avatar
Did it vibrate before the umi ta relocation kit?
Old 05-03-2012, 05:09 PM
  #33
94dragbird's Avatar
No. I did the relocation kit when I still ran the 10 bolt and didn't have a problem
Old 05-04-2012, 10:33 AM
  #34
mine is the adjustable umi arm with the drive shaft loop that mounts to the body..... i was told the axels may be untrue
Old 05-04-2012, 11:05 AM
  #35
94dragbird's Avatar
Both mine are true
Old 05-04-2012, 06:25 PM
  #36
dud u have them checked?
Old 05-04-2012, 09:09 PM
  #37
94dragbird's Avatar
Yeah. It vibrates even if I pull the axles out of the diff and run it up to speed
Old 05-05-2012, 06:50 AM
  #38
what do u think it is?
Old 05-05-2012, 10:02 AM
  #39
94dragbird's Avatar
Its just about got to be in the house or diff. Im bought ready to give up on it
Old 05-06-2012, 11:06 PM
  #40
25thhawk's Avatar
You said you tried 2 different driveshafts, what yoke(s) did they use? I had a yoke from strange that just didnt fit in the tailhousing right. It wobbled a little, like it was loose in the bushing or the splines werent cut right. I bought a new yoke from Mark Williams and it fixed the problem. Also verify that the driveshaft is the correct length, that could cause the same problem.
Ryan
Quick Reply: Vibration after rearend install
