Vibration after rearend install
Old 04-22-2012, 08:14 PM
94dragbird's Avatar
Default Vibration after rearend install
I bought a used s60 last fall and have had a horrible vibration ever since. I have changed driveshafts, changed axles, changed ring and pinion, balanced the tires, adjusted my pinion and and control arms, aligned it. Everything I can possibly think of and still get a vibration. Is there anything else I can try to solve my problem?
Thanks, mike
Old 04-23-2012, 01:32 PM
355z28's Avatar
Mike have you pulled the axles to take to a local machine shop to check runout? I would have them put them on the lathe and put a dial indicator on it to make sure you don't have a bent axle.
Old 04-23-2012, 06:14 PM
94dragbird's Avatar
Brand new axles man. I've tried it all
Old 04-24-2012, 06:33 PM
Whiteaw57's Avatar
are you 100% sure you have the right length driveshaft?
Old 04-24-2012, 06:40 PM
Blu99T/A's Avatar
Balanced the driveshaft?
Have you put the rear in the air and ran it?
Old 04-24-2012, 06:52 PM
94dragbird's Avatar
Yes and yes. I was told the torque converter could do it too. It does it the worst above 60 in overdrive but in 3rd it isn't bad until about 80mph
Old 04-24-2012, 07:32 PM
Blu99T/A's Avatar
I know you said you replaced the driveshaft, but did you check the u-joints or replace them? U-joints usually vibrate more at cruise speed or upon deceleration.
Old 04-24-2012, 07:58 PM
94dragbird's Avatar
Yep. Checked them in both driveshafts. The are good.
Old 04-24-2012, 08:04 PM
96lt4c4's Avatar
Run it on jack stands and make sure the wheel are spinning true.
Old 04-24-2012, 08:25 PM
94dragbird's Avatar
Already tried that too lol
Old 04-24-2012, 08:39 PM
Blu99T/A's Avatar
Have you checked your pinion angle?
Old 04-24-2012, 09:35 PM
94dragbird's Avatar
Yep tried that too
Old 04-24-2012, 10:28 PM
Blu99T/A's Avatar
Check the output shaft on the tranny?
Old 04-24-2012, 10:30 PM
94dragbird's Avatar
Ill try that soon as I get off work tomorrow
Old 04-24-2012, 10:59 PM
bwkmaro's Avatar
does it vibrate above 60 with the converter locked? because you could prob rule that out then. also did you blow your last rear and lasts why you got the dana?
Old 04-24-2012, 11:02 PM
94dragbird's Avatar
Yes it does vibrate with the verter locked. The rear never broke, tried to avoid that lol. I got the 60 because it wad used and a good deal.
Old 04-25-2012, 07:39 AM
355z28's Avatar
did you change the trans mount at all when you did this? Usually the Poly mounts are different heigh then the factory one and will cause one hell of a vibration.
Old 04-25-2012, 07:52 AM
94dragbird's Avatar
Put a new factory style rubber mount in it
Old 04-25-2012, 08:51 AM
SuperSport01's Avatar
List your entire drivetrain and chassis setup.
Old 04-25-2012, 09:07 AM
355z28's Avatar
New mount before or after the installation of the rear?
Quick Reply: Vibration after rearend install
