8.8
Ok, so I may have an 8.8. I'm not sure how to read this tag but it reads: S613c R
3L373 88 7a28
Any one know what this means? Which one do I have?
3L373 88 7a28
That's what I was thinking, but I was most concerned with the traction lock part of the differential. The only down side I see to this one is the 28 spline axle. But, then agin it should work. And I can upgrade the center section at a later date to 31 spline and upgrade the axles then also. I'm going to pay $200.00 for it so it seems like ok deal to me. What do you think?
Cheep is good! I'm most concerned that I will be able to upgrade this rear to 31 spline center section and axles. So far from what I have found, I think it's possible, and pretty cheep. Moser axles are $250-$350 and a ford performance differential is almost $300.00 I think. But for now, I'm just going to keep it simple by using my stock axles and a "hiltsy855" torque arm mount.
