Going to 410's - couple questions.. fluid, rebuilt kit, ect
Old 05-14-2012, 04:52 PM
93z383's Avatar
Default Going to 410's - couple questions.. fluid, rebuilt kit, ect
This is my second time upgrading a 10 bolt, this time it's for my new 97 z28. The posi still works great so I'm putting in some new 410's and a master rebuild kit, just have a few questions. The first time I built a 10 bolt it was on my 93, went 373's, new Auburn pro posi and Royal purple fluid, master rebuild kit. No problems so far from what I can tell but I wouldn't be able to hear noise over my build anyway (383 huge cam).
Should I just stick with regular diff fluid and the 8oz GM LSD additive, or should I use the Royal Purple again? If I use the Royal purple, do you need to use the LSD fluid as well? Royal purple says no but I want to get a definite answer from someone who knows Camaro's and knows the answer for sure.
The rebuild kit - Should I spend an extra 40$ and get the wheel bearings with the kit? Car has 170k on it but all seems well.
Any tips or helpful info is greatly appreciated. Do I have everything covered?
Old 05-14-2012, 05:40 PM
Ethan[ws6]'s Avatar
I wouldn't waste money on the royal purple personally. However, if you do decide to go that route, read the bottle. If it says it has LSD additive in it, don't worry about adding any unless you notice the clutches not slipping around turns.
Old 05-16-2012, 10:59 PM
93z383's Avatar
Sounds good. How bout the rebuild kit? Should I just pay extra for the wheel bearings (40$) while I'm in there?
Old 05-17-2012, 02:15 AM
Ethan[ws6]'s Avatar
With that many miles it definitely couldn't hurt.
Old 05-17-2012, 08:07 AM
camaroboy14's Avatar
Just to play it safe I would spend the extra 8$ bucks and add the additive .. That's my opinion, i use royal purple also and still add the additive .. I heard from some guys here they even put 2 bottles of additive, not saying that's right but that's what I heard.
Old 05-17-2012, 04:33 PM
93z383's Avatar
Yeah Auburn actually recommends 2 bottles of the 8oz additive, but they stopped putting Auburns in F bodies in 98 right? Then they were Torsen?
Old 05-17-2012, 07:39 PM
HoLLo's Avatar
Royal Purple is good stuff, but a little too pricey for my taste, especially when you have a bigger rear that holds more fluid. I did use the stuff in my old 10 bolt, and I've also used Lucas, and Valvoline. All good stuff, as long as it's not a generic store brand, you're pretty much good to go. Most new synthetics don't require the additive.
Old 05-17-2012, 09:01 PM
Ethan[ws6]'s Avatar
Right, if the oil used all ready has an additive for the clutches in it, there is no reason to add it. The only reason to add more additive is if the clutches aren't slipping properly around turns.
Old 05-17-2012, 09:06 PM
ramair 1's Avatar
I agree with ethan.I had 373,s put in last week, my rear end guy says dont need it u nless your additive doesnt have it allready.
Old 05-17-2012, 09:22 PM
fccs's Avatar
If your spending money for Royal ****, you should get Amsoil instead. Royal Purple used to be good years ago, now they are almost no better then normal synthetic, they just are hype now compared to years ago when they used to be really good stuff. Then amsoil took over in that department. I would add a tube anyways, it doesn't hurt to add it and you know your sure if you needed it that you already added it.
Old 05-17-2012, 10:06 PM
93z383's Avatar
Yeah I wouldn't pay extra for Royal purple, I'm getting it for free. I have friends in good places for car stuff hehe...
So if it's between regular fluid and RP, why wouldn't I use it ya know?
It's too late for the wheel bearings, I'm getting the gear install done tomorrow so no big deal, asked my guy and he said it's easy to put them in anyway if I want to in the future, just need to pull the cover drain the fluid pull some clips off and go.
I get my gears installed for 100 bucks. Last time he put in my new posi, gears, and rebuilt everything with the master install kit for 100 bucks, he does great work too. CAN'T WAIT! This car's gonna be a BEAST with full bolt-ons & 410's.. I love the M6 I will never own an auto sports car again.
Old 05-17-2012, 11:07 PM
fccs's Avatar
In that case I would do the same haha. 4.10s in a m6 is one of the best mods I have had done!
Old 05-17-2012, 11:16 PM
93z383's Avatar
Nice man, could you tell me a little about it? How big of a performance increase did you notice? Also how was your drivability and mpg, did it make a big difference around town and on the hwy in 6th gear?
I can only speak for car's I've done that have been auto trans.. I did the 373's in the Camaro, that was decent but not as great as I expected. I did 410's in a Mercury Marauder, that was nice but the car was so big any mod you did counted almost for nothing.
Old 05-18-2012, 03:35 AM
therabidweasel's Avatar
Auburns were an option after 98, well at least SLP offered a tightened Auburn in 02 with the SS, which is what I have. That said, I run amsoil for everything except the rear. Auburn explicitly says not to use synthetic. . .are you guys running synthetic and still getting good lock from an Auburn posi? I might try that now because mine is so tight that it is a little scary in even the slightest turns. . .it doesn't chatter and bind in parking lots etc though.
If you want to use the pipe method to drive the wheel bearing you need the carrier out. Otherwise you need to get a bearing puller and slide hammer. . .$60-$100 for both if you buy, or my pep boys rents. So what I'm saying is it will be no more than $100 more expensive to do it later, but with that mileage why gamble? Just do it.
Old 05-18-2012, 03:40 AM
93z383's Avatar
I have RP synthetic in my 93 with a new Auburn Pro posi, 373's, and it works great. No noise, no problems, it's everything I could expect it to be.
Old 05-18-2012, 10:36 AM
Ethan[ws6]'s Avatar
$100 lol damn that's cheap. You'll love the 4.10s. I put 4.56s in my car last year and I instantly fell in love haha
Old 05-18-2012, 11:55 AM
HoLLo's Avatar
Yep, I'm even considering 4.22s/4.33s for my 9". The 4.11s are still very street friendly.
Old 05-18-2012, 06:06 PM
cdenu95z28's Avatar
Would any of u recommend 4:10s in an A4 cars stock Sept for cat back and what other things would I have to do to accommodate this upgrade
Old 05-18-2012, 06:34 PM
HoLLo's Avatar
Catback only car? There is no reason to run 4.10s at all in that car. Get a stall, some headers, intake and all those goodies first.
Old 05-18-2012, 08:56 PM
My6speedZ's Avatar
3.73 seems to be the goto gear in a A4
Quick Reply: Going to 410's - couple questions.. fluid, rebuilt kit, ect
