more bad luck.. - LS1TECH
more bad luck..
Thread Tools Search this Thread
Old 05-28-2012, 12:20 AM   #1
Default more bad luck..
i'll start off by saying i have a 10 bolt with 4.10 gears and a m6. i've beat the on the car pretty good waiting for the rear end to go. it took about 3 months of beating on it and tonight something went lol. i was at about 5k in 1st and shifted into second when i heard a POP followed by griding and what seemed to be something flopping around. first thing i thought of was i broke a u joint but as soon as i touched the brakes the noise went away but i pulled off anyways to look. i seen nothing wrong so i decided to limp it home since i was onlt about a mile away. i pulled out and there were not weird noises until i came to a hill and there went the beating/flopping around sound. do you guys thing i just broke a tooth or what? i plan on pulling the cover off tomorrow
danrun is offline   Reply With Quote
Old 05-28-2012, 01:02 AM   #2
Ethan[ws6]'s Avatar
Are you sure it's in the rear end? can you feel the "beating/flopping" sound in your floor pan? Could be a broken torque arm mount. Just seems weird that it completely goes away at some points. Leads me to believe it isn't in the differential at all.
Ethan[ws6] is offline   Reply With Quote
Old 05-28-2012, 01:20 AM   #3
trans_am7935's Avatar
if it was the diff, it would be a distinct clicking, and jerking or the rear end. it would probably not go away. i would also check your TA
trans_am7935 is offline   Reply With Quote
Old 05-28-2012, 01:07 PM   #4
when you put on the brakes the torque arm wants to go down(so back into place). when you get on the gas it wants to go up (unto your floor pan) deff check the TA
bwkmaro is offline   Reply With Quote
Old 05-28-2012, 04:13 PM   #5
i'll go check that right now.
Old 05-28-2012, 04:23 PM   #6
well i looked but nothing seemed loose or broken.
Old 05-28-2012, 05:22 PM   #7
i backed down my driveway, which is pretty steep, and it pulled back up it but the griding noise is awful. i backed back down and turned around and backed up the driveway and it was like nothing at all was wrong.. any more ideas?
Old 05-28-2012, 05:50 PM   #8
Spider gears is my bet.
therabidweasel is offline   Reply With Quote
Old 05-28-2012, 09:09 PM   #9
BlackLS1Bird's Avatar
Quote:
Agree 100%. That was the same exact scenario when I broke my 10 bolt spider gears. A hard 1-2 powershift and bang. I wasnt able to get just the spider gears for the diff. Had to get a new casing that fit the gears. Broke that too. Hence, the 9". If your gonna keep the 10 bolt, upgrade to something stronger like a detroit locker or even a spool. Only way to really make a 10 bolt last any amount of time. Good luck with the repairs.
BlackLS1Bird is offline   Reply With Quote
Old 05-29-2012, 03:28 PM   #10
WonBadZ28's Avatar
I would hardly call blowing a 10 bolt bad luck, it is more like a forced opportunity!
WonBadZ28 is offline   Reply With Quote
Old 05-30-2012, 11:46 AM   #11
Big Al's Avatar
Quote:
Took the words right out of my mouth
Perfectly normal 10 bolt.
Al 95 Z28
Big Al is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Radiator recommendations ('06) LAYGO Cadillac CTS-V 2004-2007 (Gen I) 39 01-31-2015 12:32 AM
Really odd issue when bleeding Tick master SilverGhost Manual Transmission 5 10-06-2014 04:24 PM
Replacing inner tie Rod questions??? boola1341 Suspension & Brakes 6 03-14-2014 11:25 PM
Front Bumper Support Transam1 Drag Racing Tech 15 01-25-2014 12:39 AM
Im stumped... clunking Black02SLPSS Gears & Axles 28 11-29-2013 10:20 PM
Tags
2000, automatic, broken, camaro, gears, jerking, ls1, spider, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
