RPM calculations
Old 05-31-2012, 06:29 AM
oldmano2z's Avatar
Default RPM calculations
can you guys help me with rpm calculations on rearend ? i tried the f body.org website again this morning and got this in all rpm fields "NaN" am i doing something wrong? told ja i'm a tech dummy. i'm wanting final drive M6/3:73 rpm combo's and M6/ 3:54 rpm combo's any other sites a sticky on this site? thanks in advance... the oldman........
Old 05-31-2012, 12:35 PM
SSCamaro99_3's Avatar
Did you input all the appropriate information?
Old 05-31-2012, 12:36 PM
ShifterLou's Avatar
If you have an iphone there is a great app for this stuff.
Old 05-31-2012, 03:19 PM
Big Al's Avatar
http://4lo.com/
Select on the left side.
Al 95 Z28
Old 05-31-2012, 06:15 PM
oldmano2z's Avatar
big al , i looked and the section of gear ratio's and it says install 5 out of 6 to get the answer you are looking for what do i install in the transfer case ratio? i told you guys i'm a tech dummy and i don't have an iphone sorry when it comes to the information super highway i'm still on a dirt road.. the oldman....
Old 05-31-2012, 07:03 PM
blue98Z's Avatar
This will get you in the ballpark.
http://www.f-body.org/gears/
Old 05-31-2012, 07:39 PM
guppymech's Avatar
On the f-body.org gear calculator when entering the gear ratios use a . instead of a :
It should work then. ex. 3.73
Old is just a point of view!
Old 06-01-2012, 09:11 PM
oldmano2z's Avatar
thanks folks, guppytech, that was it on the f-body gear calc's use . instead of: thank you!!! very much!! the oldman....
