rack backed into cover, but looks ok
I thought I needed a new rear. It seems that last night my rack pushed back into the cover. I thought the rear exploded but it looks fine. It has a few scratches around the ring. Has anyone ever seen this? Do you guys think I can just put on a new cover. Weird thing is I was able to drive 4-5 miles home with no oil.
What are you talking about "rack"??? You lost a bolt in your posi and it spit around and the ring gear smashed it through the cover (from the inside). Pieces of it may or may not be still floating in the rear. This is a very common problem with the torsen posis.
Look on the side of the posi, you may need to spin it around to see the one hole that's missing a bolt. Search around, lots of other threads pertaining to this also. Its one of the most common failures.
in the 1st pic,the broken head of the bolt is laying there at the bottom in plain sight.
the rest of the bolt,I assume, is still in the unit.
https://ls1tech.com/forums/gears-axl...c-failure.html
Just took another look. The bolt head is actually in the picture. Laying at the bottom. There Is hole on the inner ring of bolts that seem to connect the ring. Actually it appears that the ring is connected by the outer bolts and these may be the bracket. Anyone know the size? I'm wondering if I can just screw a new bolt back in without disassembling the rear.
