broken rear studs ..
I have a quick Q about replacing them .. I pretty much remove eveything down the my rear rotors, unplug the abs sensor at the back, then there will be a small hole where I can knock them out ? If im rong can someone please correct me.
thx ,
Paul
thx ,
Paul
You can replace rear studs on the stock 7.5" 10 bolt without pulling the axles. I have done it. Unbolt the calipers, remove the rotors and drive the broken stud out with a punch. By rotating the axle, you will find a spot where there will be enough room to insert the new stud. Use a stack of washers or a couple of large nuts and a stock lug nut to pull it into the flange.
