8.8 axle "walking" out - LS1TECH
Thread Tools Search this Thread
Old 07-07-2012, 01:20 PM   #1
AJGls1's Avatar
Default 8.8 axle "walking" out
bought a 93 mustang with a 6.0l th350 8.8 combo, when i loaded it on trailer after buying it, it leaked gear oil out of pass when it was leaning a little to that side, got it home and took axle out to find that the axle wasnt all the way in the bearing, the gears had just been changed so i thought maybe it just didnt get pressed on far enough, after some street time i noticed last nite its come back out a little, it has c-clip eliminators, im going to try a new bearing and see if that works but has anyone else had this problem?
AJGls1 is offline   Reply With Quote
Old 07-07-2012, 02:50 PM   #2
Big Al's Avatar
Quote:
The "C" clip eliminators I know about use the axle bearing to retain the axle. You need to take it apart and see what's happening. It should have a heavy stamped steel retainer bolted to the end of the axle tube to hold the outer race. The inner is held by a steel collar that's pressed on the axle behind the bearing.
Al 95 Z28
Big Al is offline   Reply With Quote
Tags
88, ls1tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
