Will i run into any problems? - LS1TECH
Thread Tools Search this Thread
Old 07-26-2012, 05:41 PM   #1
reeperz28's Avatar
Default Will i run into any problems?
I recently purchased a complete rear end for cheap out of an m6 car with 3.42's and want to swap it into my a4 car that has 2.73's . Is there anything different between the two or should it be pretty straight forward swap? If there is differences could i just swap the carrier and gears out of th m6 rear end into myne?
reeperz28 is offline   Reply With Quote
Old 07-26-2012, 07:08 PM   #2
Big Al's Avatar
Need to know what year the car and the rear end is.
Al 95 Z28
Big Al is offline   Reply With Quote
Old 07-27-2012, 08:33 AM   #3
reeperz28's Avatar
02 camaro came out of a 02 car
Old 07-27-2012, 11:10 AM   #4
FirstYrLS1Z's Avatar
channel differences could be an issue
3 channel=ABS
4 channel=ABS & TC
vehicle ? channel
replacement rear ? channel
FirstYrLS1Z is offline   Reply With Quote
Old 07-27-2012, 12:32 PM   #5
reeperz28's Avatar
Well is it alright to just change the rear carrier and gears rather than swapping the whole rear out?? Or is there more to it i have a ratexh deluxe install kit
Old 07-27-2012, 07:19 PM   #6
Big Al's Avatar
Quote:
There is a lot more to it. Swap out the complete axle assembly.
Al 95 Z28
Old 07-28-2012, 10:36 PM   #7
SS SLP2's Avatar
Quote:
Al 95 Z28
^^^^by far the less problems
may have problems IF one is 3 channel and other 4 channel
I have forgotten just what will need to be exchanged just do a search on here for info
Johnny
SS SLP2 is offline   Reply With Quote
Old 07-29-2012, 09:42 AM   #8
I asked the OP in post #4 what the channels are and no response.
Tags
02, 28, 95, assembly, changing, end, girdle, install, pads, rear, replace, year, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
