9" Install Question - Lower Control Arms?
While bolting things back up today I noticed that there is a pretty big gap in the LCA mount points on the new Moser 9" rear. It is probably an 1/8 to a 1/4 inch. I have BMR LCA's (poly/poly) and I know with the stocker they had to be worked into position with very little to no gap (actually had to pound them in a bit) but not on the Moser.
Is this a big deal? I'm assuming that it isn't correct but I don't really know how I'd go about fixing it since I can't very well shrink the mount point to remove the gap. I guess I don't know if lateral movement on the LCA's is going to be a big deal or not since they are more there for front to back stability (or at least that's how I understood it)
There is still a gap when you TQ them to 87 foot lbs? Try that first, if there is still a gap maybe the bushings in the LCAs are wore I know when I installed my LCAs with rodends, where the LCA mounts on the body of the car (not the rearend), I had a gap until I TQed it to 87 foot lbs.
good to hear.. I called Moser today and they swore up and down that they are built for the stock LCA's and that is why they are so wide... funny thing is that my BMR poly LCA's were the same size as my stockers.... someone measure once instead of twice on that one..
I'll try torqueing them and if that doesn't close it all I'll do the washer trick. They also said to use washers if need be.
