will the stock rearend hold or waste money
Old 08-12-2012, 01:35 PM
k_garretson23's Avatar
youre lucky its holding now. If you enjoy spinning with bad tires then sure itll hold a little longer but throw tires at it and itll grenade. 4.10s will actually make it weaker because the teeth on the ring and pinion will be thinner. Invest in a good rear, youll be happy you did.
