rearend torque specs?
Old 08-17-2012, 05:39 PM
jc98ss's Avatar
Default rearend torque specs?
i am about to swap my rear with another 10 bolt......does anyone have torque specs for the bolts i'll need to mess with outside of the housing like LCA's, PHB, sway bar mounts, driveshaft yoke, etc......any special torque specs on the inside if i end up having to swap the differential? (carrier bearings, etc)
Old 08-18-2012, 01:10 AM
guppymech's Avatar
These are the numbers from my factory service manual for my 1994 TA.
DS U bolt, 16 ftlbs
LCA 60 ftlbs
shocks 66 ftlbs
panhard bar 75 ftlbs
torque arm 97 ftlbs
Old 08-18-2012, 01:20 AM
jc98ss's Avatar
DS U bolt, 16 ftlbs
LCA 60 ftlbs
shocks 66 ftlbs
torque arm 97 ftlbs
awesome, thanks man....do you know the specs for the carrier bearing caps?
Old 08-18-2012, 01:30 AM
guppymech's Avatar
Carrier bearing cap bolts, 55 ftlbs
ring gear bolts, LEFT HAND THREAD, 89 ftlbs
rear cover bolts, 22 ftlbs.
Old 08-18-2012, 01:33 AM
jc98ss's Avatar
thanks again guppy.....i'm good to go now!!
Old 08-18-2012, 01:36 AM
guppymech's Avatar
Glad to help a guy out who knows the importance of doing it right!
Quick Reply: rearend torque specs?
