banging after rearend install
Just installed my new 12 bolt and i have a banging from ther rear when i go over bumps! everything is tight i checked it. is it possible to have a spring in the wrong position that could cause that?
Like you said make sure everyting is tight. I had the same problem and one of the long bolts that holds the sway bar to the mounting points on the body was bad and was allowing it to bang around. Also if you put in tougher suspension like LCA's and TA it will transfer more road noise into the car.
JR
JR
I have the same thing after installing my 12 bolt and relocation brackets and i cant figure it out i checked everythinga zillion times and everything looks good. I have the BMR lowering springs in there and dont know if thats the problem but g-d is it annoying!!!!!!!!!!!!!
good call jimmy ill try that. one of my lca was a little loose so i tightened that and it helped a little but there still somethin making noise i find it if i have to replace the whole rear suspension
ok guys i figured it out. my rear sway bar was hittin the rearend. so i fabbed up some spacers to slide between the muffler clamps and the sway bar mounts and that cured the niose plus the car handles alittle better
