Making Stock Limited Slip Slip Less?
Is there anyway to install stiffer springs and/or install preload shims under the stOck springs without disassembling the rear axle?
Try running less friction modifier or no friction modifier. That will make the clutch plates grab more. A friend who off roads told me it's common for 4x4s to run without friction modifier when they plan to do alot of off roading for more grip, then before they leave they put some friction modifier in the diffs for street use.
