newbie? 3.90 gears
http://www.richmondgear.com/101032.html
With my 4.10s, my 26" M/T's, I can get 130 out of 4th (6900RPM) before I would be getting out of my powerband at all. My car makes 470whp from 6000RPM to 6900RPM, so I don't think running out of RPM will be a problem any time soon. Not just that I will be adding a FAST to my setup eventually - should rev even higher theoretically. I will probably run 4.10s once I get a strong rear and just run a taller tire if I need "more gear."
With that said, if I am having trouble running out of gear (trapping 130+) I will have no problem switching to 3.90s, haha.
Good luck fri. Post up results!
My shift light is currently set at 6400 and the only pass I made it was just coming on as I went through the traps at the 1/4. I only could make one pass before it rained, but I definitely think the calculations I have done are good. I still had probably another 600RPM to go before the limiter. Anyway the pass sucked so I am not posting up results, but overall I like the gears.
