Moser 9 U-joint?
Moser 9 U-joint?
Can anyone tell me what i need to do with the u-joint? Since they are different when attaching to the moser nine from the drive shaft? can i go to a parts store and make a franken u joint? guidance is needed please
You mean you need a u-joint with 2 different sized caps? They make em. And no, trying to swap caps on u-joints is a very bad idea. Ask me how I know.
Anyways, they make adapter u-joints. Find out what sizes you have, do a lil foot work and life will be good.
LS1Tech Sponsor
Yes, go to Napa and ask for the 447 u joint. I have info at this link that might help you out. http://shop.brutespeed.com/Moser-12-...structions.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
K how about this, and thank you all by the way. How exactly do the axles not come out? i have two seals, two press seals, and two bearings.... i remember seeing something about a c clip eliminator, do the f bodys have/need them? this is driving me crazy, tomorrow i am going to get all the stuff i need, (as if $3400 wasnt enough) and i feel like im missing something, mainly whatever keeps the damn axles from coming out. what a pain! oh and here is the fun part.. Moser sent me all kinds of instructions, instructions on how to install the ring and pinion set, how to assemble the eaton detriot locker, which is fantastic considering they are already assembled. but the one thing i needed help on, i didnt recieve instructions for. Ive searched for hours on the net, and im starting to come to the conclusion that the instuctions dont exist, its really simple, and im an idiot making life harder for me
Thoughts?
Thoughts?
Thoughts?
Thoughts?
LS1Tech Sponsor
Thoughts?
Thoughts?
The Moser installation instructions are the first thing you see at the link I sent you up above. When you press the axle bearings on the axles and then bolt the caliper brackets back up, this is what keeps the axles from coming out. This is the preferred method of containing the axles, instead of using c clips. Bob
__________________
Alright, here we go! after putting the dif in there is no access for the common clips to be put on, verified that much by the shocking lack of a groove for said clip on the axles. obvisouly this rearend doesnt use clips so it must use something else to keep the axles from slipping out. right now my question is what keeps the axes from coming out when i dont intend them too. For some reason i cant upload pictures I will try again
LS1Tech Sponsor
__________________
Hey Thank you for that info Bob, i was kinda leaning that way, but im sure all can appreciate not wanting to be ***** deep into something and realizing you cant finish! I mean i hate that more than anything in this world. Didnt see the link tho Bob
Yeah so i got the damn thing in, as it turns out (thank you Bob) it wasnt nearly the pain in the rear that i thought it was going to be. i was stuck on a part that my car didnt need. The backing plates hold the axles in, again thank you Bob. Now i have two or three problems. The studs that come with this rear end im sure have not completely set into the housing, i will confirm that in a few days, the rear leafs? i guess! are about 1/8 of an inch loose, of course the drive shaft is too damn short as well. I bought a bushing kit, so hopefully that will fill the void for the leafs, im pretty sure that the short drive shaft is causing a small clunking noise when i disengage and engage the clutch, and i am not overly pleased with the way the studs worked out for the differential. however this is an awesome rear end.
