Moser 9'' 31 spline axles how much hp?
So I recently got a Moser 9'' w/4.30 gear, spool, and 31 spline axles in my M6 Trans Am.
My question is on an ET Drag will I twist my 31's? How much hp are they good too? Right now the car sits at 408/392 but will be closer to 450 next week and then nitrous..
Just wondering how much strain they are good for on an M6
uhhh your kidding right???
I am making over 5xxwhp and launch the ever living hell out of my 9"... **** ain't gonna break. Axles are good for over 1000hp lol.
funny you made 408whp, I made 404 on motor with the same combo well w/ the 224r cam and Fast 90 w/ 92mm tb/ LS6 heads through my 9" rear before i did the blower.
Care to be a bit more specific I don't understand.
I thought there were two cases
3.026" bearings for 28-31-33 spline centers
and 3.25" bearing for 35-40 spline centers
That was the way the guy at Quick Performance made it out, said if I ever planned to go up to 35 since I was M6 then I should just start there and eat the cost, because it would cost the same amount to do it over because I would be buying the diff and case and axles to go 35 later from say a 31.
I dont know about other companies stuff but I found this doing some other research.
Joe
Let me know if your interested. LOL
You can run a 35 Spline Axle in a Small Bearing Case with a Mark Williams Spool that is made for that application. I'm not sure if it requires Mark Williams Axles or Stock Type Splines!
Joe
Joe
I twisted a few 31 spline Moser shafts on my 8.8". I ended up with Mark Williams shafts and they're working great.
Although at only 400hp or so, I doubt they will ever come to any harm no matter what tyres you use.
