Rear-End Slack Diagnose (Video)
Old 10-08-2012, 08:11 AM
Corday's Avatar
Post Rear-End Slack Diagnose (Video)
Hello!
I had a lot of "slack" in the stock gears, so I upgraded to 4.10 about a year ago. It didn't have this much slack right after the install. I only drove about 40 miles since then.
Please diagnose.. How severe is this? I remember i had some trouble with the crush-sleeve and pinion-nut during the assembly.. Could that be the cause of this or do i need to take it apart and re-shim?
Thanks!
Old 10-08-2012, 04:20 PM
FirstYrLS1Z's Avatar
looks/sounds excessive. is there any 'play' in/out or side to side ?
Old 10-08-2012, 08:14 PM
bwkmaro's Avatar
it doesnt look thatttt bad but that could be the posi to zexels have a good amount of play
Old 10-08-2012, 08:18 PM
the torsen play occurs between the ring gear and the axle shafts internally in the torsen unit. the play in the video is beween the pinion gear and the ring gear.
Old 10-08-2012, 08:47 PM
Schitzo's Avatar
I would start by checking that the pinion preload and backlash are within spec.
Old 10-08-2012, 10:18 PM
01ssreda4's Avatar
I would pull the cover and check backlash on the ring gear. You don't check it from the front so it can be deceiving from that video.
Quick Reply: Rear-End Slack Diagnose (Video)
