Strange 12 Bolt Rear End Cover
I have a cheapie chrome cover seems to be leaking and the abs sensor wire is broken, again so I may as well out a decent cover on it. Do I need the low profile cover or will any cover work? The two I am considering are below. Would prefer the Trick Flow, going to have to call Strange in the morning for the sensor any way.
Low profile
http://www.taperformance.com/proddet...?prod=TA_1810A
Or can I use this guy which I would prefer since I can just snag it off of Summit's site?
http://www.summitracing.com/parts/TFS-8510200/?rtype=10
Neil
Low profile
Neil
They're nice covers but do you know if that's the standard or the low profile cover? If you don't know that's fine, I'll give them a shout in the a.m when they're open. Most likely order the low profile cover
Your's is the standard cover, they only make two covers for the 12 Bolt car and logos between the lower profile and the standard cover are a bit different. I just noticed that for some reason. I called them this morning and ordered the lower profile cover, it's only a 1/4 inch shorter, but any thing helps.
