Can I safely hook?
Old 10-16-2012, 12:47 PM
ANGRY BIRD's Avatar
Default Can I safely hook?
We all know that the 4L60-E/ and 10 Bolt rears are prone to breaking when you hook 'n book with an LSX in front of them, but how about my V6?
Don't make too much fun... It should be running 220 RWHP/ 220 TQ. I wouldn't think that would be too much for them to handle with some drag radials and hooking on a launch would it?
Old 10-16-2012, 12:54 PM
zacht's Avatar
i would say your fine...for some reason some 10 bolts make it down into the 10's...and pull some damn good short times behind the A4...i think your good...
Old 10-16-2012, 12:58 PM
ANGRY BIRD's Avatar
Yeah im shootin for low 14's lol
Old 10-22-2012, 09:29 PM
VincesSS's Avatar
I agree, should be ok.
Old 10-22-2012, 10:38 PM
ANGRY BIRD's Avatar
I should've probably mentioned it's still a one winner spinner, Series 2 carrier.
Old 10-24-2012, 06:06 PM
NVR_SPDS's Avatar
Put a posi in it, and let her eat! The biggest advantage of the auto in front of the 10 bolt is that when you foot brake it, the ring and pinion are loaded, and ready to go, as opposed to the sudden impact/load behind a 6 speed. Thats why the 6 speed is a 10 bolt eater, and the auto is much less of one lol.
Old 10-24-2012, 06:17 PM
3.8redbird's Avatar
Will a 4L60e bolt up behind a 3.8? I thought they used a different trans mount up.
Old 10-24-2012, 06:50 PM
ANGRY BIRD's Avatar
Did not know that! makes complete sense though.
Yes, that what you have. The V6 has a differnet bolt pattern Pre 98's or 99's were solid casting cases, so they were not interchangeable, but the later 4L60-E's the bellhousing was bolted to the main case, so all you would need to do to switch a v6 4l60 to a v8 or vise versa is change the bellhousing.
Old 10-24-2012, 08:53 PM
Grr
Grr's Avatar
I have been cutting 1.60s and running 11.4s all fall with a 10 bolt and 4.10 gears. Around 450whp. STarting ot make noise now though
Quick Reply: Can I safely hook?
