9 Inch LT1 brakes issue
Old 10-17-2012, 08:54 PM
White6SpdZ28's Avatar
Default 9 Inch LT1 brakes issue
]So bit the bullet and bought a 9 inch off a member here. Was set up for an LT1 car and I know I have to swap backing plates. Issue I am having is is there a special tool to unbolt the LT1 backing plates??? I can't fit a socket in there and the nut is recessed so I can't use a box wrench. Any help is greatly appreciated.
Old 10-17-2012, 11:26 PM
1961ba427's Avatar
Can you put a socket on it without the ratchet attached first, then put the ratchet on the socket after the socket is recessed onto the nut down the hole? That doesn't leave room to back the nut out, but you can hold the nut on that side and use another ratchet to pull the bolt out from the inner side.
Old 10-18-2012, 12:35 AM
Heyfred's Avatar
Drill hole in axle flange.
Old 10-19-2012, 03:01 AM
Kevin97ss's Avatar
I ended up making a specialty socket out of an old extra. Had to take some off of both sides using the bench grinder.
Old 10-19-2012, 07:46 AM
I was thinking if just grinding a socket down. Seems the easiest
Old 10-19-2012, 09:11 AM
Kevin97ss's Avatar
Just don't go too far on the hex side. If you need an extra 1/16 you can get it from the drive side.
Old 10-19-2012, 02:32 PM
Well honestly don't even need much to get everything in. I figure if I break the nut loose I can probably spin it off by just the socket
Quick Reply: 9 Inch LT1 brakes issue
